Traxxas 3727A Battery Hold Down Plate, Grey: Rustler, Stampede
We compared price of Traxxas 3727A Battery Hold Down Plate, Grey: Rustler, Stampede across hundreds of online stores. We found Traxxas 3727A Battery Hold Down Plate, Grey: Rustler, Stampede in 1 store with lowest price $2.30 in Trainz.com. For detailed price comparison of Traxxas 3727A Battery Hold Down Plate, Grey: Rustler, Stampede check table below.
Merchant | Price | - |
Trainz.com | [show price] |
Traxxas 3727A Battery Hold Down Plate, Grey: Rustler, Stampede description from Trainz.com
This is a Traxxas 3727A Battery Hold Down Plate, Grey: Rustler, Stampede. Features: Metal Post and Body Clip replacement parts for the Rustler truck.Includes: 1 Black plastic hold-down plate, (2 5/8 long, 3/8 wide andhas 2 holes that attach to the posts) .2 Metal posts (Aluminum with a hex shaped top and holefor the body clip, threaded on bottom) .2 Steel body clips.Comments:Body clips are bent for easier installation.Condition: Factory NewOperational Status: FunctionalOriginal Box: YesManufacturer: TraxxasModel Number: 3727AMSRP: $3.00Category 1: Other ToysCategory 2: Radio Control ToysAvailability: Ships in 3 to 5 Business Days.The Trainz SKU for this item is P12087275. Track: 12087275 - FS - 001 - TrainzAuctionGroup00UNK - TDIDUNK
Customer review
I am so happy I bought hobbies. They fit well, look really expensive and will look great with anything. The Traxxas hobbies are well-made ...
